Hey Thanks for all of your help.I see in you sig that you have a few mods that catch my attention if you don't mind please explain what these are or anybody .Thanks i am new to this . IAH Delete, FPR mod, HX mod, EBPV Delete, Map mod,
Thanks Again,Robby
IAH=Intake Air Heater removed. This is a heater designed to heat the air being drawn into your engine. Provides quicker warm air to the engine. It's also a significant restriction to your airflow. Unless you live in a very cold climate. You probably won't need it.
Remember diesels want to move more air, in and out, and more fuel to go with it.
FPR=Fuel Pressure Regulator. A shim is installed in the regulator to increase the fuel pressure. Mine is running at Approx. 65#'s
HX mod= High Pressure Crossover Hose. The oil that runs your injectors enters the engine at the rear of one head, travels the length of that head, crosses over, and then travels the length of the second head. This causes the last injector in line to be starving for oil sometimes. The hose attach's to two existing ports about halfway down the engine and and lets the oil cross to the other head sooner.
It makes your truck run slightly smoother and quieter too.
EBPV=Exhaust Back Pressure Valve removed. Just post turbo is a flapper valve that closes when the truck is started cold and provides a restriction in the exhaust to help the engine work a little harder at idle which causes it (the engine) to warm up faster. Also a restriction in getting air out of the engine. (See above). Again, if you don't live in a cold climate you probably won't notice it's gone.
Map Sensor Mod. This allows me to boost over the factory set safety limit of Approx. 24-26#'s If the computer sees a reading in excess of the factory safety limit it will de-fuel the engine causing power loss at high RPM's.
Man I hope I got all of that right. /ubbthreads/images/graemlins/phoney.gif If I did not, I know someone will come along and correct me. Hopefully politely.
Hope this helps,
Tom
