Thought I had a battery problem took out had charged, found to be starter fixed that. Hooked batteries back up, turn key truck started like it should.
Now I have no door charms when door is open and keys in, radio has to be powered on and off manually doesn't shut off when door is open, my inside dome light doesn't come on when door is open.
My power door locks dont work at all. I can list more, stuff does work just not the way they did before I disconnected the batteries.
I did check all the fusees under the driver side. all where good. Not sure if any more fusees anywhere else
02 F250 Super Duty 7.3
Truck runs good, power windows work and AC/ Heater and all that.
Just dont know where else to look or where to start to look.
Discussion Starter #2
Just adding, with keys in hand, Power windows and radio work when they should not be working.
