1 - 16 of 16 Posts
My Mom boyfriend give me is Autostart AS-1755 witch was install on is 7.3 van (don't recall the year, 99-03). now my service manual on my computer decide to not give me any wiring diagram for ignition switch connector and i can't find one on internet witch as the same color code as my 02.
what i found so far
2 yellow - 12V
Red/black - ignition
Lt gray/yellow - ACC
Dk green - starter
does this look right?
Here's the Ignition switch connector pinout.
Thanks klhansen thats what i was looking for
Ok, this is the first time i install a remote starter so not really sure where im going.
look like i need 6 relay for start.
relay 1 - starter killer
relay 2 - IGN 1
relay 3 - IGN 2
relay 4 - ACC
relay 5 - Door unlock
relay 6 - Door lock
do i need a IGN 1 relay or the starter kill relay will do both?
96Cobra, thanks for the site it was helpful
so i got pretty much everything install for the start portion. BUT when i start the truck with the remote, truck fire up, starter does not stop and shut off after few second.
look like the module doesnt know the truck is running. My guess is i have the wrong TACH wire.
with the 4 service wire inside the cad i have 2 other (so 6 total) , for what i read, the green with white line is CTS (clean tach signal) can some one confirm
Discussion Starter · #10 ·
Thanks yes it did confirm and i got it figure out.
my problem was the programming of the unit. you have to program the TACH rpm when idling so when the engine reach this RPM it will stop the starter.
I did the programming a couple time whit no success until i decide to use the whisper mode from my chip (lower the RPM for drive thru) and it work.
Discussion Starter · #11 ·
so this is what i used to install the remote starter on my truck (in case someone need some info)
I have another PDF witch is Ford alarm 2002 and up but its too big so if your interested PM me I might be able to send it by Email
Back in 2006 when I installed my Ford remote start and alarm, it required a "tach module" to be installed inline because it could not read the RPM from the diesel engine. Other than that it was too long ago for me to recall specifics.
Discussion Starter · #13 ·
For what i read the wiring is pretty much the same (with some differences) from 02 to 05. I know the wiring is way different from 01 to 02 so maybe its the same from 05 to 06.
Maybe it would function better with a TACH module but now everything does is think like it suppose to.
Ill do a bit of research!
Discussion Starter · #14 ·
For those with remote starter, REAR YOUR MANUAL if you didn't do it yet.
There are some programming that can be done witch if the system got install professionally you have 50/50 % chance it was done right or like you want it
After reading the manual a couple time, I changed the programming to be diesel specific.
Turbo cool down (60sec after exiting the vehicle)
Cold weather start (will start the truck for 20min each 2h for the next 24h or until cancel)
Open/close windows using lock/unlock button
My system is pretty basic so you with better system have probably lots a nice goodies to play whit
Glad you got it working. I had a shop do mine back in '03 so I couldn't help much, other than offer up the12volt site.
Discussion Starter · #16 ·
well that just enough to do what i had to do thanks body
1 - 16 of 16 Posts
