Hi!
Normal a.m. start about 30 degrees, warmed up fine. started off to work. 10 minutes later at 55 MPH truck loses all engine power-no shudder no surging just off- like the solenoid clicked off but it is not the solenoid. Stopped the truck in a safe place and recranked- nothing- then it sputtered a bit, ran rough and stopped, crank- crank-crank sputter, rough died. I want to save battery power for later so I stopped messing with it. I pushed the bleed valve and lots of air in there. What are the most obvious choices. I have new return line kit at the house, and new return check valve and schrader will be there today. Could this be my lift pump crudding out on me?
Need to fix this one quick.
