I have a 2003 6L diesel F350 crew Cab with electric locks and key Fob
I need help from you all , here is my question I would like to hook up a switch outside the truck ( like a hide a key ) that will trigger the doors to unlock if pushed. the reason is I did a key lock delete on the door being they now have the same door handle as the back door wit no key , so unless someone breaks the glass there not getting in , if they pop open the side door handle the rod that the key would turn is gone. anyway so now i have to rely on my key fob and if i loose it for the battery goes dead i screwed so i want to hide a button i can oust , and i need to know were and what color the wire is that will send power to the door unlock relay ?
thanks
chad in AZ
