I'm working on a friends vehicle (o.k., it's actually a car but I know you guys can help). We replaced the drier, orifice tube and evacutated the system. It should hold 2.5 cans. We only got one can in and the low pressure sied is showing high pressure (about 90 psi) and the high side is showing low pressure (about 120 psi). It would not take any more 134a and nothing was cooling. The compressor was on continuous and all the lines were hot. When we pulled the orifice tube it was chock full of junk. His system worked before we started (it wasn't working well, only blew 70 plus degree air) but he had mistakenly added 134a to a r-12 system. He took it to a mechanic and they evacuated it again and said the compressor was bad. I'm wondering if maybe one of his lines may be plugged since the orifice tube was full of junk, or, maybe the 134 and r-12 screwed something up.
