Hi,
I have pretty much everything for my conversion. I am using a A1000, Mallory 4305M bypass regulator, and a Daveco 234 plus fuel processor. I am running 1/2" alluminum lines for the WVO supply and return lines.
I still need 2-4 check valves (would like source suggestions here) depending on how I setup the engine compartment, and the various fittings. I am tryint to stick to alluminum and Stainless for all the fittings. I alo am intending to run the return WVO fuel through the fuel supply rails (I am keeping the #2 fuel return stock). I am thinking about mounting the regulator near the firewall on drivers side, connected to the two back ports of head. I am also planning to connect both the #2 and WVo through check-valves, into a Stainless cross fitting, and then into the front two head ports. I am having trouble deciding how to route the hoses, in an attempt to keep them short (purge time) and also for fear of getting to close to the turbo housing in the rear. I am debating between braided SS hose, or Aeroquip socketless hose, but am unsure of heat problems. Socketless hose only seems to be rated for up to 180 degrees (water).
Also, do you need to remove AC compressor to get to the front passenger side fitting? Is there room to run the hose out of that fitting with the stock AC mount?
