2004 350 HD crew
I've replaced the alternator with high output(230) and two new motorcraft batteries and still will get a slow turn over in the morning
once truck is running and the alternator kicks in it pumps 13.5-13.8
I plow with the truck as well as have a big stereo and HID lamps. had no real problem until this year. tough winter in New England and truck had to stay outside the garage.
did a drain test by dis connecting the battery neg cables and did the test light to cable/battery, pulled each fuse one at a time and no diff
checked all cables for wear/bare spots, haven't checked the grounds yet
took out the fuel heater relay to see what if any difference that would make. turned over a little faster than usual
was wondering *** is up with the charging system
