1 - 15 of 15 Posts
Discussion Starter #1 (Edited by Moderator)
When I was repairing the rat damage to the wires a couple of weeks ago, I noticed oil in the ICP connector, so I started shopping... $140 for the Ford F4TZ-9F838-A, so I took a $25 chance on a cheapo, knowing I could put the original back if necessary. I wasn't expecting any change in the engine because I wasn't replacing it for any driveability symptom. But I'd swear I could tell a difference in the way the engine revved, just sitting there trying to see if it would leak. After driving it for a day, I'm still trying to decide if I'm imagining a difference, or if it's really running better.
Is it possible for the ICP to make a noticeable change in the way the engine responds to the throttle, and how much pep is in its step?
If the ICP was biased low, it would increase the pressure to the injectors. Kind of like the old 10k resistor mod. If the ICP reports a lower pressure than actual, the PCM would boost IPR duty cycle to compensate by bringing pressure up to what the it wants.
So within pinpoint test Z: ICP, the only test I see for the actual ICP output is to read the PID before cranking to see if it's 0 (Z13). No way to check the sensor bias. So does that mean that the PCM will adapt to the new ICP and go back to its prior performance? Or do you think the old sensor's leak was actually causing its reported pressure to fall the longer the engine ran; and since this one isn't, the engine will actually continue to run this well?
That's possible, but your previous ICP would have had to have been reporting higher than actual, which isn't that likely. The PCM can't adapt, it just reacts to the voltage that the ICP is sending it.
You'd have to put a HP gauge on the system and look at the voltage vs. pressure chart for the ICP to figure out if it's in the right range.
Pressure (PSI)​
Pressure (MPA)​
Sensor Voltage​
0​
0​
.02v​
200​
1.5​
.4v​
400​
3​
0.73v​
600​
4​
.96v​
800​
5.5​
1.2v​
1000​
7​
1.4v​
1200​
8​
1.6v​
1400​
9.7​
1.9v​
1600​
11​
2.1v​
1800​
12.4​
2.3v​
2000​
13.8​
2.6v​
2200​
15.2​
2.8v​
2400​
16.5​
3v​
2600​
18​
3.3v​
2800​
19.3​
3.5v​
3000​
20.6​
3.8v​
OK, thanks. I can't imagine finding a Tee fitting with those threads & O-ring, so I'll just ride it.
Discussion Starter #6
If you've got a spare HPOP hose, you can install that in any of the head oil rail ports and adapt to a 0-3000 psi gauge. No need for a tee (although you could find one at a hydraulic shop).
Discussion Starter #8
No, I don't have those, and I don't know of a hydraulic shop. The last few times I've tried to buy hydraulic fittings online, the sellers didn't have what I needed & told me to make my own.
BTW
That cheapo sensor just dropped to $15.42 . I'm tempted to buy another just as a spare, or to compare performance.
Try here for an adapter from Female o-ring boss to pipe threads. I wasn't able to find a female ORB to female pipe, but a pipe coupling is easy to find at a hardware store. You'd have to verify the size. You could also use a male o-ring boss to female pipe adapter directly into the head, if there's room for the gauge screwed into it. You'd need to confirm the oil rail plug size. I can't remember for sure but I think they're 5/16, or -05 in "hydraulic-speak". Would be the same as the ICP sensor threads.
What's the source for the cheapo ICP? Might be handy to have one in the go-box for an emergency spare.
Discussion Starter #10 (Edited)
The word "cheapo" in my first post is an Amazon link.
...and now there's a $2.00 coupon, making it $13.42+tax.
So my next question would be: which ports in the heads are for that oil rail? Any that I find along that surface? Are they all ORB? Are their plugs just screwed down, or are they also threadlocked? I think I'm seeing 4 per head in this pic: the one with the right-angle fitting (coming from the HPOP?) and 3 hex-head plugs:
(phone app link)
So the Left head would have 2 plugs, the HPOP line, and the ICP?
That is correct. Passenger side would have 3 open spots and HPOP line. They are o-ring boss, but forget the size (I think -05). Cheers!
The pigtail is probably worth the $13.42, with a free ICP thrown in. (y)
So I bought one of the Cheapo sensors. Interesting item. It has an International PN on it, and no identification of country of origin, either on the part or the box. The PN means nothing, though, as I don't think International can copyright a number. Anyway. It's an insurance spare.
157400
Discussion Starter #14
I've seen many modern knock-off parts that use the OE PN. It's slightly annoying because you can't use the PN any more to weed out the copies & find the genuine part; but it's helpful when the genuine part is out of production, because it makes the copies easier to find.
Still a smokin' deal for an emergency spare or even one to help someone else out of a jam. I carry a bunch of stuff in my toolbox just in case I could help someone else in need out 9and myself of course). Cheers!
1 - 15 of 15 Posts
