Have you actually checked the glow plugs? The GPR cycling doesn't mean anything if the glow plugs are burnt out.
Check here for how to check them.
Have you actually checked the glow plugs? The GPR cycling doesn't mean anything if the glow plugs are burnt out.GPR cycles.
WIRING DIAGRAM!!!! You rock! I'm baffled by the WTS as well. If there's no ground to the PCM - it shouldn't trigger a WTS - should it? I think I'm missing something. Unless as you mentioned, ground is being provided. I talked to a Ford tech that's been around long enough to spend time under a 7.3 hood and his comment about ground was "Ground is ground - shouldn't need the key on or a sensor to be working for there to be ground. Ground is ground". He said if I can't find where the ground is bad "just feed it a new one". Might give that a try to see if I can get the PCM to communicate with the DLC. Feel like I'm throwing darts at the wall until I can pull codes. Thanks again for the diagram!The ground for pins 51, 77 and 103 of the PCM (black/white wire) and the ground for pin 26 of the IDM (black/pink wire) are in the engine compartment next to the fuse box (ID is Ground G-101. PCM pin 25 is grounded separately thru a light blue/yellow wire to ground G-100 which is located on the cowl panel above the fuse box. G-100 also provides ground to the PCM power relay coil.
Those are all the grounds I can find for the PCM, so I don't understand how if those grounds are disconnected you can get a WTS light, unless possibly a ground is being provided through one of the items that the PCM controls.
You may have something bad internally in the PCM assuming you don't find a problem in the wiring harness.
Here's a wiring diagram that may help.
Thank you sir!Here's a Crank no start flowchart...
Thanks! Haven't seen the top pic before. Appears to be more grounds to the PCM connector than I've been testing. I've found all all the under-hood ground connections (G102, G104, G100, G101) removed and cleaned them. I did get pins 25, 51, 77 and 103 to read ground in the PCM connector last night after cleaning everything. Crank no start condition yet. I still don't have output from the DLC. I need to run that down and get this thing to cough up a code or I'm still throwing darts. Appreciate you!Can you get eyes on the S106 ground splice and the G101 ground location that feeds these PCM grounds? I can't tell exactly where the S106 splice is, but the Ford Service Manual says: In engine harness, near T/O to PCM. Anyone know what T/O stands for?
An illustration of the G101 location is below.
WAIT!!!I've got something wonky in my PCM as I'm still unable to successfully connect anyone's scanner to it (OTC, Bosch, Snap-on, Bluetooth dongle) through the DLC. Nothing communicates with my PCM - still unable to pull codes. Going to send the PCM in for testing/rebuild.
I think he's got power. Are the grounds on that connector good as well? This pic is from a thread that PaysonPSD posted on: SCANNER NOT COMMUNICATING WITH PCM...7.3 - Ford Truck Enthusiasts Forums...Can’t pull any codes – power to DLC, but no comms...
Thanks for this! Sorry for the delay......been out of town for a few days and not working on the truck. All fuses have been checked and rechecked. Still no comms. Goind to check the DLC tonight against the info BWST shared - see what that yields. Pulled inner fender out to accesss IDM and PCM plug in. IDM looks like it's terribly corroded (MN winters). Looks like it might disintegrate if I get too aggressive on removal. Not sure it's related to my problem - but it will be soon! Going to test the 5V circuit (Pin 90?) against each of the sensors on that circuit (unplug each sensor individually and see when 5V returns). Maybe she'll fire if one of them is the culprit. Blood pressures down again - it's just a truck. I have others. Peace all!I think he's got power. Are the grounds on that connector good as well? This pic is from a thread that PaysonPSD posted on: SCANNER NOT COMMUNICATING WITH PCM...7.3 - Ford Truck Enthusiasts Forums
