just purchased a 97 F350 ambulance with 7.3 engine and 160k miles at gov deals auction. In the advertisement it stated was running when parked, now starts only with ether. I just called the manager of the storage lot and he informed me that it would only crank, not start. then they shot some ether and it fired up and died. THen they decided to drain fuel bowl and fill with fresh gas (truck has been sitting for approx 1 year near Charlestown, South Carolina), and it started and ran for a while until fuel bowl filled with water again then it would die. This is my first diesel engine. I have been googling and you tubing everything of 7.3 power stroke. I am unsure the best way to approach getting this truck running reliably.
I am in central Florida and will be driving up to South Carolina on Memorial day, spending the night and viewing/visiting/fixing truck 0900 Tuesday morning. Its in a remote lot with no electricity and 3-5 miles from a gas station according to google. I don't know how he confirmed that water is the problem, or he just assumed it was water. He said the pump must be ok because it refilled the bowl. I think the best woud be to completely drain both tanks-I guess around 20gal each, then fill with fresh diesel, drain bowl and clean, install new filter, and cross fingers a hope it runs good.
That would require up to 40 gallons of tankage to hold the old diesel. And I would need at least 5gal of fresh to get it running and drive 5-10 miles to gas station to fill up. Or if water settles to the bottom of tank then if I suck from the bottom of tank until I get just diesel then I might not need so many cans? I have heard that the end of the pickup tube is like a 1/4-1/3 of a tank from the bottom? So, that would be like 5-8 gallons? Can a diesel tank get that much water in it from sitting a year? Is it possibly something else? Of course it can, but what? He said it ran good with fresh fuel in the fuel bowl so that would rule out injectors and high pressure oil pump problems right? As well as cam position sensor, ICP sensor, And oil pressure sensor, and even the IPR or whatever the high pressure pump is abbreviated. I would greatly be beholding to any insightful info you can give. Its remote location, distance from auto parts stores is like 50 miles, and my ignorance is making me nervous. I only have 1 day to get it right and then drive 6-7 hours home. Thanks n advance for any info. I thought about an inline water separator like in boats but it dont take a ton of water to fill them up. If the fuel filter got wet initially does it not let diesel fuel through after that? questions going round in my head
