1 - 13 of 13 Posts
Jason,
Roughly since the server problems you had the other day, the new posts flag has not been working for me. They are always on. I have tried clearing my local caches, etc. But no luck. Just FYI.
BTW, thanks for providing us with this site, it is incredible. I have learned so much in the past few weeks! I'm even more excited about my truck now than I was when I ordered it. Now if I could only get this damn pyro question resolved
2000 F250 SD CC LB 4x4 Lariat,Dp Wdgwood Blue/Harvest Gold, PSD, 6SP, TT, ESOF, LS, Capt Chairs, etc.
Ordered: 7/26/99, Status as of 8/20: To be built 9/20, ETA 10/11
You need to go to "preferences" and click on the link to delete all cookies. This will fix it up for you. Just make sure you also reset your preferences afterward. It will prompt you to do so.
Rob Spading - Webmaster
Turbo Diesel Register Website
http://www.turbodieselregister.com/
Nope, that didn't do it either.
You might try resetting it again using the Delete all cookies option in Preferences. Cookies are a strange deal to get working correctly sometimes.
Jason
Ford-Diesel.Com Webmaster
1997 F-250 PSD 5-speed Banks Stinger-Plus
I'm having the same problem and the "preferences" thing didn't work for me either. Any ideas?
"Moby" a.k.a. Oxford White 2000 F350SD SC SRW LWB 4x4 PSD 6SP X31 617A Z1 22 99F 446 55R 531 T4R 63T XD1 592 54Y 67B 924 948 86R 433 58K 18L 674 90P 96P. As of 8/18/99, serialized & locked in, to be built week of 8/23, ETA 9/6/99. Yeah baby!
Michael Kasimirsky
I've been having the same problem with the "flags". I've gone and reset the cookies multiple times along with clearing out the disc cach and temp files. Is there anything else I can do to try and get the lights and flags working right again? It's a real pain to try and rember where I left off and track the times of the posts. Plus the times on the posts are still way off.
Local time 1635
1997 F250 5spd SC SB 4X4 XLT
[This message has been edited by JJ (edited 08-30-1999).]
I think the post times are right now. Remember that I'm in Eastern Daylight Time right now. This post should show up as being around 6:50 or so. As far as the cookies, I have had to go in and manually edit mine before. I use Netscape, but don't know the procedure for IE. If you use Netscape, let me know.
Jason
Let's see if we can narrow this down a little. If the folders and light bulbs aren't working right for you, first try this:
<UL TYPE=SQUARE>
<LI>Click on the Preferences link at the top of the Forums page
<LI>Click on the link at the end of the first paragraph to "Click here to delete all cookies set by this forum!"
<LI>Go back to the Preferences page and tell it store your username and password for a year and set the number of days to display topics
<LI>Click on the Forums graphic at the top of the page.
<LI>Click on the Forums graphic at the top of the page again.
<LI>All the lightbulbs should go out and it should tell you when you last visited.
[/list]
If this doesn't work, post the browser type and version that you are using (like IE 4.0, Netscape 4.61, etc).
Jason
I tried that just before logging off and went and again cleaned out every catch and file with cookies and temp files I coud find. Upon logging on their was no lightbulbs at all.
I went back through and did the Preferences thing again and then the lightbulbs showed up . Think everything is back to normal finally!!! Think what threw me off with the time was the 0 in front of the time. To me that normally means AM.
FYI we are using Netscape Communicator 4.6
http://www.tcsn.net/doncicci/freedom.htm
http://www.thewowfactor.com/bigbroncos/detail.cfm?detailid=220
Jason,
I have the same problem. I use netscape communicator 4.6.
Went through your steps above several times. Nothing is being reset. Light bulbs do not go out.
96 F-350 PSD XLT CC DRW 4.10S
Banks power pack, Hayden cooler, U. S.Gear Exhaust Brake
ISSPRO Digital PYRO, ISSPRO Boost & Trans gauge, A-Pillar mount
32' Hitchhicker
God's country-TEXAS HILL COUNTRY
I don't know how familiar you are with computers, but here is what you need to do:
<UL TYPE=SQUARE>
<LI>Make sure Netscape isn't running
<LI>Click on Start, then Find, then Files or Folders
<LI>Type in cookies.txt in the Named box and make sure Look In is set to C:
<LI>It should find one in something like C:\Program Files\Netscape\Communicator\jlester
<LI>Double-click on the file to open it in your default editor
<LI>Look for any line that has ford-diesel.com in it. There may be several. Delete all lines with ford-diesel.com. Make sure to delete the entire line, but none of the other lines around it.
<LI>Save the file and exit
<LI>Startup Netscape, go to my Forums page, click the Preferences link and reset your preferences.
[/list]
I've submitted a bug report. This problem will hopefully be fixed soon.
Jason
Thanks Jason,
Looks like every thing is reset.
JLester,
I followed your steps on how to edit the cookie.txt file and since then, all of my topics icons are working correctly.
MANY THANKS!!!
MAP
'00 F250 Lariat PSD,CC,4x2,SRW,SWB,4R100,3.73LS,TT Pkg,
Capt. chairs,A.R.E. bed cover,Line-X bed liner,Nerf bar steps
Green/Gold
Conceived: 6/08/99
Delivery: 9/20/99 est.
1 - 13 of 13 Posts
