New Problem. The other day my 97 F250 started cranking slowly and the voltmeter took quite awhile to get up to its normal position (between the R and M of NORMAL) went to a parts store and had the batteries tested and they were fine but the alternator tested bad. Replaced the alternator and now the volt meter jumps up to the L of NORMAL..........Right after i replaced the alternator I was just letting the truck idle awhile and it started running badly coughed a few times then set a "check engine" light and smoothed out again. I shut it off, then awhile later went back out, fired it up and it was fine and no "check engine" light ... Last night I left the store put the truck in reverse and it starts chugging and coughing, put in in neutral and it smoothed out and I drove it home and it was ok. Any thoughts.....
Jeff
Jeff
