I have read a lot about the folks who have had the valve problems during regen cycles and the fix Ford has put out.
Fingers point to build up on the valves...or tight valve guides. If the change in programming changes the way the truck regens, why won't Ford reprogram all the trucks as they come in?
Is there any benefit to having the new program installed if not experiencing the problem?
If people have build up on their valves, then won't we all have build up? As I am sure we are all running quality oils at proper maintenance intervals.
Thanks,
Cale
I have wondered the same thing. I had thought about seeing if local dealer would perform the flash.
