New Starter Choices...Please comment.
5652 Views 45 Replies 9 Participants Last post by  F450Diesel
I need a new starter for my 96 7.3. I'm posting here because of the bigger # of people up here. I had planned to get one from DB before it failed. Well I may have missed that chance and I'm not giving up my weekend. I wante dto go DB because they are new and an upgrade. I have now found a local rebuilder / warehouse that matched DB with the same units. DB has 3 on their site, my source has 2 of them in stock at prices that match DB including freight.
My first choice is the 4kw Nippondenso (I have heard it described as one big bad starter) at $169.95
They also have the 3.6kw Mitsubishi PLGR at $119 This is a 3 bolt maybe the same as my stock one?
My local source doesn't have the OSGR 3.6 KW 2bolt 2001-2003 unit.
My local guy (who I use for lots of fleet big rig stuff) says the 4kw unit is just more robust and will survive abuse such as extended cranking better than the other.
Any one have any bad experience with the big 4kw Nippondenso?
Cost isn't really the issue, the old one has 200,000 miles on it, so the new one should last 10 more years
41 - 46 of 46 Posts
Just ordered this
will let you guys know how it works out.
had my starter tested (AC Delco), turned out to be a bad solenoid, but no one sells them separately so I had to just get a whole starter (least it was cheaper than the local prices by about half).
I just received my replacement from DB. Again, it says all over their ebay and website that its a 4kW motor but the individual spec sheet shows it tested at 3kW. The guy said he doesnt false advertise and that all of them are 4 but now Ive spoken to several other buyers who have 3 kW spec sheets. Interesting.
Being tested at 3KW & Being rated at 4KW are two entirely different things.
rated at 4KW just means it can handle that kind of peak output.
Sorry---meant RATED.
Well Starter works great.
starts quicker than the AC Delco one did.
My spec sheet for the DB also shows the 3kW rating. When I called, they told me it was the correct 4kW unit.
The new starter is twice as big and heavy as my old one, which is why I was not too worried about the spec sheet. It turns the engine over so much quicker. The difference is night and day. I am looking forward to testing it out in the cold next winter considering that my old starter really struggled below freezing temperatures.
41 - 46 of 46 Posts
