Okay. I have had the truck for a week now and have spent probably too much time searching the posts here and this is the plan of attack I have put together. Please provide any feedback - I am look for anything I may have missed, or something which is out of priority. Thanks.
Order Cost Description
0 0 Door Ajar Light Fix
1 15 Oil Drip - Purple Power/ clean intake valley - identify source the leak
2 200 Trans Cooler upgrade - 6.0 31 row cooler
3 100 Synthetic Tranny Oil swap
4 0 Door Lock thermister fix
5 10 Rear End Clunk - grease the slip joint
6 100 Synthetic Oil swap
7 150 Oil Bypass filter
8 70 coolant Filter
9 15 Steering wheel wobble - fix with turn signal release and gear indicator correction
10 70 Tymar intake DIY w/ 6637 filter
11 10 ZooDad
12 20 HPOP Seals
13 20 Turbo Pedestal Seal
14 20 Fuel Reservoir Seals
15 0 Hutch Mod
16 0 Harpoon Mod
17 55 High Pressure Oil Crossover upgrade
18 30 Glow Plug relay upgrade
19 20 CCV Mod - w/ catch can at the back
20 100 Wheel Bearings - front then rear
21 10 Dipstick O-ring replacement
22 0 Battery indicator - intermittent
23 10 Power Steering - sluggish and small leak
8 70 coolant Filter
11 10 ZooDad
12 20 HPOP Seals
15 0 Hutch Mod
16 0 Harpoon Mod
