Vendor
Light the way in your 2011-2016 Ford Super Duty with the XDP X-TRA Bright Stealth LED Light Bulb Kit XD347. The XD347 adds X-TRA Bright LED lighting to the front of your truck with an easy, no-hassle installation. Simply remove and replace your existing turn signal/parking light bulbs with the XD347 “Stealth” LED Bulbs. This allows you to retain full function of your turn signals and parking lights but adds a powerful set of LED lights to your existing headlight housings. The X-TRA Bright Upgrade Kit adds an additional 8,000 lumens of light to the front of your truck! It’s like bolting on an auxiliary LED Light Bar, but keeps a clean stealth look and doesn’t require drilling holes on your roof or bumper!
Each bulb features (2) amber LED’s and (1) X-TRA Bright LED. Each kit comes ready for installation and the X-TRA Bright LED’s can be wired to any 12-volt power source, or switch of your choice.
FEATURES:
X-TRA Bright CREE LED’s
Direct-Replacement For Factory Bulbs
Amber LED’s Retain Signal/Parking Light Function
Adds 8000 Lumens Combined Using Existing Headlight Housings
SPECIFICATIONS:
Amber LED Output: 108 Lumens per LED (2 Per Side, 432 Lumens Total)
White LED Output: 4000 Lumens per LED (1 Per Side, 8000 Lumens Total)
For more information on the XDP X-TRA Bright “Stealth” LED Bulb Kit XD347 – Click Here
