In February 2011 I purchased a re-maned Detroit 12V92 . To my understanding it was test on the dyno for 16 hrs prior to picking it up. I transported it without any problems mounted it to a Ingersoll RAND drilling rig. It is now April and it still wont start.
We have tried and double checked everything without any success. We have also invited several so-called diesel mechanics out to help trouble shoot. We all come to the same conclusion. IT SHOULD START.
Of course it is under warranty and we have contacted Diesel Exchange. Without any satisfaction. Since we were started into a hole when the old one gave out on us it is imperative we get this thing going. Our next step is to contact Stewart Stevenson $$$$$$$$$$$$$$$ To assist.
Your help and suggestions or any input at all will be greatly appreciated.
- WE HAVE FUEL, AIR AND OF COURSE COMBUSTION, BUT IT WONT FIRE
- IT BLOWS BLACK SMOKE OUT THE STACKS
- BTWN 60-80 LBS OF FUEL PRESSURE ONCE THE INJECTOR PUMP PICKS IT UP
- WE HAVE BLED AND PRIMED SEVERAL TIMES EVEN THOUGH ONCE SHOULD HAVE BEEN ENOUGH
- WE HAVE A PUMP TO GET THE FUEL TO THE INJECTOR PUMP.
- REPLACED STARTER WITH A GEAR-REDUCTION STARTER IN HOPES THAT WE POSSIBLY WEREN'T GETTING IT TO CRANK FAST ENOUGH
- WE DIDN'T TRY A DRY RUN AND WENT AHEAD AND CONNECTED ALL ACCESSORIES, ( Ingersoll RAND SCREW/VEIN TYPE COMPRESSOR TO THE REAR AND THE HYDROLOIC PUMP FOR THE DRILLING UNIT ON THE FRONT. HOWEVER NETHER ARE UNDER LOAD.
