pro's or con's... i rode in a nissan with the cvt and the car shifted smoothly through it's range (i would say gears, but i don't think it has gears). i don't know a thing about the tranny...any info would be helpful?
I'm not acquainted with the Nissans, but I'm familiar with the theory of the system. To put it in simple terms, you have a drive pulley, and a belt which drives the driven pulley in place of a regular transmission. The shives of both pulleys can vary themselves in diameter according to vehicle speed, engine RPM, load, power demand, etc. For example, starting out up a steep hill, the drive pulley will be small diameter, the driven pulley large diameter to gain maximum mechanical advantage. (Like starting out in low gear with a normal trans) On the other hand, when cruising along under a light load, the shives on the drive pulley come closer together forcing the belt out while the shives on the driven pulley widen so the effect is like a high gear. The drive pulley is then turning less RPM than the driven pulley.
I don't have a clue if I'd like it in a car or not, but my Polaris 500 Sportsman has it, and I really like it in that application. It's always in a good RPM range for whatever the speed and conditions are.
