I am new to Diesels. I just aquired a 1980 SD33T out of a Scout, I actually have the entire drivetrian...the frame axles(d44 w/truetrac locker) transmission(t-19) and engine. I am wondering if this engine is worth transplanting into something like a toyota truck or the FJ 80 landcruiser. Can I add a intercooler and succesfully turn up the boost and the injection pump for more power? With only 100hp/175ft.lbs torque is it a lost cause, to heavy and not enough power? or potential? just looking for input and Ideas. I don't want to have a impractical truck that will not go over 65mph.....I'm told the Scout was SLOWWWW with this engine. Howerever I can live with slow if I get good MPG and can tow somthing at above 55mph. What about mating it to a toyota 5 spd with a .75 overdrive gear? and 4:10 axles and 35" tires??? thanks in advance
I do know someone who has one of the Scouts with one of these, I was kinda jealouse of it until he had to rebuild it. The pistons etc were really outragous. He's still running it, likes the mileage but the performance is slow. Kinda old tech. I'm sure the turbo and the aftercooling could be improved, but you would absolutley kick it's butt with a 4bt 3.9 Cummins, so if you are going to build a whole vehicle around it......I'd say not. Sell all that stuff to the Scout guys and get a 4bt.
REDTOY,
You may want to visit www.redpowermagazine.com for a better answer to your question. Many folks over their have scouts and are also very well versed about scouts.
Thanks for the advice, I'm not sure what I'll do. I kinda want to work with this engine since I already have it. Any idea how much weight this engine would push down the road twoing or not?
I'd keep it. I see no reason why you couldn't modify it, its been done before. Heck, people are making 600 HP out of 175 HP Cummins, I'm sure you could double or triple yours. Check out Binder Bulletin, there's a couple forums there you can try. Also keep in mind the Scout was fairly heavy so if you don't increase the power, a lighter vehicle would help too.
