1 - 14 of 14 Posts
Nitro Chromoly Cut to Length Rear Axles
Nitro Gear & Axle now offers an assortment of Heavy Duty Cut-to-Length (CTL) rear axle shafts. The CTL axle shafts feature extra Long splines and can easily be cut to the desired length with a chop saw. This allows Nitro to use stronger rolled splines rather than cut splines and allows fewer part numbers to cover a wide range of OE and custom applications. This also makes it easier for Offroad, restoration, and Rod Shops to stock axles since they fit so many applications.
Nitro Gear & Axle strives to provide the highest quality differential & axle components available. We take the steps necessary to ensure our parts are dependable. Our product range is continually growing to meet the needs of consumers for new ratios and applications. At Nitro we know differentials, and know what it takes to provide you with high quality components.
Discussion Starter #2
Check out all our front and rear axles and accessories here! We keep many models of axles in stock and can answer any questions you may have about what parts are right for your application.
This 900 HP Dynomite Diesel Products pulling truck limped in with 3 broken axleshafts after a recent event.
Up front the broken OE 30 spline shafts were swapped for Nitro alloy 35 spline assemblies, An Auburn Gear, LLC Aftermarket Products Ected Max Elocker was installed in the Dana 60, new Nitro 5.13 gears and all that beef contained with Nitro Billet main caps.
In the rear Dana 70 out came the damaged OE 32 spline components and a custom machined Dana 80 37 spline Nitro Spool, Nitro ring and pinion and 37 spline Nitro Alloy axleshafts were installed along with another set of billet bearing caps to keep everything together.
Maximum durability combined with maximum traction this beast is ready to get back in competition! Check out all the NITRO Gear Chromoly Axles here. We have front and rear axles for many applications that include CTL (cut to length) shafts custom length applications.
Discussion Starter #4
Our gears and axles are built to handle all types of abuse. Check out this 454ci powered Wrangler running Nitro equipped Dana 60s playing is some standing water:
Discussion Starter #6
Check out our full compliment of axle shafts by vehicle manufacturer here. We stock a huge number of front and rear axle shafts for many different vehicles. If you have any questions, or can't find what you need, give us a call at 866 349 6801 or email us at [email protected]!
Discussion Starter #7
Got Axleshafts? Odds are we have what you need (or want) in stock. Here's a pic of just one of our axleshaft storage areas in the warehouse. Stock to high grade chromoly we have you covered. Give us a call at 866 349 6801 or email us at [email protected] for a quote.
Discussion Starter #11
Loads of axles in stock now. Get 10% off your axle kit when you purchase a gear package for the entire month of November!
Order any Nitro Gear Package and receive 10% off on up to 2 lockers, LSD units, spools or chromoly axle kits, and more for your rig. Take advantage and save hundreds on gears, lockers, and axle upgrades now. This is not an online special so call 866 349 6801 and speak with one of our differential experts for an ideal combo for your rig!
Check out the packages available at the link and then call 866 349 6801 to order:
NITRO Gear Packages
Discussion Starter #13
No matter what you drive, or where you're going, we have the NITRO Gear and Axle parts to get you there! Check them all out at JustDifferentials.com or give us a call at 866 349 6801 and we can help you buy the best parts for your axles.
Discussion Starter #14
Do your gears and axles have what it takes to get you where you want to go? Check out our website for chromoly axle shafts, U joints and birfields, complete axle upgrades and more. If you can't find what you need or if you have any questions give us a call at: 866 349 6801, or email us at: [email protected]
1 - 14 of 14 Posts
