1 - 20 of 35 Posts
Nitro Gear packages for your vehicle, now with 1 part number!
Nitro Gear and Axle has led the way for many innovating R&P and axle packages. Now they have simplified the way you purchase gears. With one part number you can purchase your front and rear ring and pinions, master install kits, solid preload spacers, and new yokes if they are required. No more searching around to find the correct install kits and ratios for both your axles!
Do you really need new gears in your axles?
It is a common misconception that Re-Gearing a vehicle is only for Hardcore Off-roaders or for huge oversized tires. In fact, most of the late model vehicles we produce aftermarket ratio’s for are daily driven vehicles with slightly oversized tires. In an effort to improve fuel economy, Late model overdrive transmissions are geared very high which means RPM’s are very low on the highway. When even a slightly taller tire is installed the RPM’s are reduced below acceptable levels that the engine was designed to run. This causes constant shifting out of overdrive, sluggish acceleration, poor economy and rapid wear on the transmission and other components.
By changing the Ring & Pinions in your vehicles differentials, you can match the ratio to the tire size to bring the RPM’s back to where the manufacturer intended. Typically it is recommended to select a ratio slightly lower (higher numerically) than what the math will tell you. This will help accommodate increased rolling resistance, wind drag, and added weight of aftermarket accessories and gear.
If you have any questions or need a quote, contact us
Discussion Starter #2
It is a common misconception that lower gears are only for hardcore off-roading, in actuality the average daily driven vehicle can see huge improvements in both performance and economy by properly matching their vehicle’s gear ratio to their tire size all while reducing strain on the vehicles drivetrain.
We at Nitro Gear & Axle realize how confusing and difficult it can be for the average consumer or gear installation shop to compile the list of gear parts and prices required when doing a complete front and rear gear change. To make it easier for everyone the experts at Nitro Gear & Axle are introducing an industry first - "Gear Packages"
These gear packages are specifically designed for many popular 4x4 applications such as the Dodge Ram, Chevy/GMC 2500/3500HD, Toyota Land Cruiser/FJ Cruiser/4-Runner/Tacoma/Tundra, Jeep Cherokee/Wrangler/Rubicon and Ford F250/F350 Super Duty.
These gears are manufactured from 8620 steel forgings and are precision machined using a computer controlled process. Heat treatment, CNC triple-lapping and Rockwell testing for hardness ensures excellent fitment, ideal contact pattern and smooth, quiet operation.
Nitro Gear & Axle sells ring and pinions for more than just the Dodge, Chevy/GMC, Toyota, Jeep and Ford vehicles listed in our gear package section so please contact us if you don't see your vehicle listed in our gear packages.
Bumping this back up! We have gears for many more axles then are listed under our Gear Packages. If you can't find what you're looking for online, send us an email or give us a call.
Discussion Starter #6
Congratulations to Jessi Combs and Nicole Pitell-Vaughan for successfully completing the Rallye Aïcha des Gazelles in their Total Chaos Fabrication Inc. built Tacoma. This truck is running NITRO gears among many other upgrades. We would also like to congratulate our friends Ronda Rhonda Cahill & Rachelle Croft of Expedition Overland on also completing the challenge.
If you are looking of the strongest ring and pinions to stand up to all the abuse you put your rig through, check out NITRO Gears!
Discussion Starter #7
Combine a Nitro Gear Package with the current ARB promotion to get a FREE compressor when you order by June 15th:
Discussion Starter #8
All web orders over $150 currently receive free shipping within the US!If you can't find the gear package for your vehicle on our website email us at [email protected] or call us at 866 349 6801.
Discussion Starter #9
We keep our gear package kits in stock and ready to ship out to you! If you have any questions let us know. If you don't see the options you are looking for, give us a call at 866 349 6801 or email us [email protected]. Check out all our gear package kits online:
Discussion Starter #11
Check out all the NITRO Gear Packages Kits we offer for Chevrolet & GMC, Ford, Nissan, Dodge, Jeep and Toyota vehicles HERE.
Discussion Starter #12
Overlanding.
I don't need to regear, my tires are only a little bigger than stock.
It's a common statement and one we enjoy addressing when the opportunity presents itself. Overland preparation tends to add weight to the base vehicle. Bumpers, winches, skidplates and tire carriers can add a tremendous amount of weight from stock. Add a rooftop tent or rack assembly up high and aerodynamic drag is greatly increased as well further reducing performance both on and off-road.
Beyond increased weight, vehicle manufacturers almost always opt for a borderline gear ratio from the factory to optimize unloaded fuel economy. This means that even running near stock size tires, a heavily loaded, taller than stock and factory undergeared Overland 4x4 is a very poor performing machine both in terms of acceleration and fuel economy. This reduces cross country fuel range, on road responsiveness and off-road control all at the same time.
The solution is regearing. Proper gear ratios put the engine at optimum RPM for performance and fuel economy and give you the opportunity to add traction aiding differentials during gear installation greatly enhancing the capability of your backcountry 4x4 in the field, on the highway and around town.
Just Differentials is the leader with gear packages available for all the common Overlanding platforms. These kits include ring and pinions, full master setup parts and everything your mechanic needs to regear your rig and make it function as it should instead of gasping every time you climb a mild grade.
Call us at 866-349-6801 or check out our package options here.
Discussion Starter #13
Bumping this back up! We always keep our Gear Packages in stock. Check them all out here. If you have any questions let us know.
Discussion Starter #15
Four Wheeler magazine has a nice write up on the drivetrain they're swapping into a Chevy Tracker including our stronger Nitro 29 spline Toyota 8 inch gears. Check out the full article here.
Discussion Starter #16
One of our customers sent us some pictures of his very cool 2000 Toyota Tacoma long travel build featuring some great aftermarket parts including Nitro Gears and ARB Air Lockers front and rear.
We keep gears, install kits, lockers, axles and tons of other small parts in stock all the time for many different makes and models. Give us a call at 866 349 6801 or email us at [email protected] for a quote today!
Discussion Starter #17
Diesel owners rejoice, Nitro now offers a 4.30 ratio for 2000 & newer AAM 11.5" rear axles!
Our brand new 11.8" AAM 4.30 gears are what every diesel owner has been waiting for. These new gears fit both the new AAM 11.8" housing and the 2000-2012 AAM 11.5" housings. Anyone with an older model 11.5" who has been waiting for gears can install this upgrade with ease. Larger diameter ring adds extra strength to your rear differential! Upgrade you GM or Dodge 2500 or 3500 diesel today.
AAM 11.8" Differential Gears
2001-2010, GM 2500 or 3500 - GPDURAMAX-4.30
GMC Sierra & Chevrolet Silverado with Duramax
Use AAM11.8-430-NG gear with MKAAM11.5 Master Kit
2011 & Newer, GM 2500 or 3500 - GPDURAMAX2-4.30
GMC Sierra & Chevrolet Silverado with Duramax Diesel
2003-2013 Dodge 2500 or 3500 - GPRAM-4.30
Dodge Ram with Cummins Diesel
2014 & Newer, Dodge 2500 or 3500 - GPRAM2500-4.30
Use AAM11.8-430-NG gear with MKAAM11.8-B Master Kit
Discussion Starter #18
The aftermarket is flooded with cheap low quality noisy and hard to set up gears that don't last when worked hard. At Just Differentials we stock brands that we believe in and hold up to what our customers put them through on the trail, race track or towing a trailer.
JustDifferentials.com for all your gear and axle needs.
Discussion Starter #19
We've been putting this LX470 together in the shop over the last few days. Recently we went through the suspension and axles, and added a Nitro Gear Package. Now we are adding Slee Off-Road bumpers, sliders and a Engo winch. If you are in the PNW and need a quote for some work on your vehicle let us know!
All our Gear Package Kits are available online. You can email us at [email protected] or call us at 866 349 6801 for a parts quote.
Discussion Starter #20
Building a sweet 9 inch assembly in the shop this week. Nitro Nodular housing, Nitro LSD unit, Nitro 1350 forged yoke and a REM treated 3.50 Nitro Gear Set. REM treating produces an incredibly smooth surface finish for reduced noise, cooler running and longer lasting gears. Ideal for keeping gear noise to a minimum and an option on some Nitro gearsets.
We can build one for you as well, or just about anything else for your axles. Call 866-349-6801 or click on the link below to see all our gear and axle options:
Nitro Gears at JustDifferentials.com
1 - 20 of 35 Posts
