21 - 35 of 35 Posts
Discussion Starter #22
When was the last time you checked your gear oil? This 10 bolt rear end came in from a local customer. Don't forget about your axles when you are performing routine maintenance on your vehicles!
Discussion Starter #23
The little guy is a Toyota 8 inch pinion gear. Big one is a Nitro 11.8 AAM pinion gear going into a new Chevy. We stock them both should you be ready to regear everything from a mini truck to a seriously built HD diesel. Give us a call at: 866 349 6801 or email us at: [email protected] if you have any questions or can't find what you need at: JustDifferentials.com
Discussion Starter #25
Re-gearing your 4x4? We stock gear packages for all the common 4wd platforms including the new 2016 Tacoma gears those trucks so desperately need after a lift and some bigger tires.
Click THIS link to order you gears today or call 866-349-6801 and speak with one of our differential experts!
Discussion Starter #26
November Gear Special!
Order any Nitro Gear Package and receive 10% off on up to 2 lockers, LSD units, spools or chromoly axle kits and more for your rig. Take advantage and save hundreds on gears, lockers, and axle upgrades now. This is not an online special so call 866 349 6801 and speak with one of our differential experts for an ideal combo for your rig!
You can see all the gear packages HERE.
Discussion Starter #28
It's not just trucks with big tires, and rock crawling that break differentials.
This happened on a stock 07 tacoma with pretty low miles. 05-15 Toyota Tacoma's with the factory locker are equipped with this tiny 8" diff. We often swap them to the much more robust 8.4 (the oem non-locking rear) with an aftermarket locker. As you can see here the left carrier bearing has spun on the journal so it slides on and off. What this did is loosen up the preload to allowing excessive backlash. The condition is amplified under heavy load, as the pinion forces the ring gear away, which eventually lead to this catastrophic failure. Check it all out at: JustDifferentials.com
Discussion Starter #29
Our Gear Packages include everything you need to regear both your front and rear axles with high quality parts. They include Front and Rear:
-Ring & Pinions
-Master Install kits with bearings, shims, seals, etc (MK)
-Solid preload Spacers if available (noted as SK in description)
-Pinion flanges (if noted with YOK)
Discussion Starter #30
Do you want 10% off a NITRO Gear Package?
Buy 1 ARB Air Locker and get a free ARB CKSA12 compressor. Buy 2 ARB Air Lockers and receive an ARB CKMA12 compressor. If you buy 2 Air Lockers you will get the CKMA12 compressor and a 10% discount on any Nitro Gear Package.
To get the Gear Package discount call 866-349-6801 or email [email protected] for a quote. Check out the link to the video below explaining the promotion!
Discussion Starter #31
10 great reasons why you should choose JustDifferentials.com when you're in need of gear or axle parts:
1. Quality Parts.
2. Fast Shipping from 2 warehouses.
3 Huge inventory.
4 Skilled differential experts to help you get the right parts the first time.
5. Name brands including: ARB, Nitro, Eaton, Auburn, AAM, Dana-Spicer and more.
6. No Chinese bearings.
7. Competitive Pricing.
8. Wholesale discounts.
9. Complete custom assembled 3rd members built to your spec.
10. Small town service.
Ph: 866 349 6801
Email: [email protected]
Discussion Starter #33
Working on something out of the ordinary? Not sure what parts you need? We are here to help! Give us a call at 866 349 6801 or email us at [email protected] and a member of our team will help determine what you need. We stock gears, lockers, axles and all the parts in between to help finish your project.
Discussion Starter #34
Another testimonial about how important having the proper gear ratio is, from JKS Manufacturing:
The JKS 4-door was great, right up to the point those awesome 37" Nitto Tire got installed with the stock gears. Nitro Gear & Axle took care of that problem and more. 4.88's, set up kits, a carrier and even those BEEF differential covers. Problem solved, and now we are fighting over the keys!
Discussion Starter #35
Now is a great time to order new gears, or a NITRO Gear Package Kit. We have tons of inventory in stock! Ask about bundled deals when you order gears and lockers, posi unit or axle shaft kit. Call 866-349-6801 and speak with one of our differential experts today.
21 - 35 of 35 Posts
