21 - 24 of 24 Posts
You’d have to be a doctor to afford to keep one of those old Tbirds running...
Hey folks!
Thanks for all your replies. I bought an extended warranty, and it looks like the system might be covered. The dryer is not getting cold at all, can't see any oily substances, so at this juncture I'm thinking the dryer might be bad?
The A/C is low on refrigerant, has a leak somewhere. Shouldn't be hard to find by the shop.
Good deal having insurance, should be back to normal soon.
Here in California we have to leave a deposit of $5 per can of 134 as a recycling deposit. 30-days to recover the $5 per can.
I stocked up while at the Idaho ranch!
Hey fordtough, sounds like your short on equipment to properly fix the a/c... it’s best to have a shop put some dye in the system and watch for leaks, fix the leaks and add the proper amount measured by weight. I know it sounds long and expensive but it’s the only way to properly fix it. “Decadents” or “air dryers” only go bad if the system is exposed to air (leaking system could do it if the leak is bad) please remember that r134 is still toxic to our environment, it’s just not as bad as r12
21 - 24 of 24 Posts
