My 90 F350 CC 4X4 has not been operated very much since last summer, but this weekend I took her for a drive. Everything was working well except the Banks waste gate was still hanging up and trying to over boost, but that is another problem. Suddenly when I applied the brakes the pedal went to the floor without any pressure or stopping. Lots of pumping got her stopped. I checked the brake fluid, and it was clean and full. After several attempts the brakes started working again, but I can press the brake pedal and the pedal moves slowely to the floor, if pressure is held. Some history follows:
- last year I replaced both the master cylinder and Power brake booster. I bled the system repeatedly and used lots of brake fluid, but never really got what I consider good brake pedal pressure.
- I can't lock up the tires, even in panic stops. I have never been able to do that in this truck.
- The reason I replaced the brake master cylinder and booster was because the brakes suddenly failed and then started working again later (same as this time). I was in some of our smaller mountains on a dirt road when that happened, and it really got my attention(scared the poop out of me and my wife).
What is the likely cause of this problem?
Thanks in advance.
hweaver
Thanks in advance.
hweaver
