In my 2002 PS I found out the other day that my truck would not start at 45 degrees F but I plugged it in and the next day at 43 degrees it started without a problem. In my 97PS I had a glow plug relay and glo plugs which could be and usually are the problem. Does the 2002PS have a glow plug relay like my 97? Also I will check the glo plugs and will probably replace all of them if its not the relay, if its called a relay. Thanks in advance
Yup. There will actually be two relays kinda right back behind the fuel filter in the valley. One for the fuel bowl heater and one for glow plug relay...pretty sure the relay used on the 2002 will look about identical to the one you were familiar with on the 97
