I don't have a ford, but wish I did. Not sure if I am aloud to post here, but looking for some help. My dump truck turn signal and flashers won't work that are connected to the steering column. The same switch has the brights and wipers which do work. Any ideas? I did already change the fuses in one spot.
To get a good answer, you'll need to tell us what kind of non-Ford vehicle you have.
Generally, there are multiple circuits to the turn signal/dimmer/emergency flasher switch, and they can go bad individually. If you have power on the proper circuit going to the switch, but nothing coming out, then the switch is suspect.
You're welcome to post here, but not in the Ford-specific forums (for other than Ford vehicle questions). I've moved your post to the Other Technical Questions forum.
The first thing to change out is the signal stat. It is usually located in the fuse box. On some vehicles one controls both turn signals and flashers and on others it takes two of them.
