Pulled cluster today and now when I turn my lights on I have no illumination. Both turn signals, the high beam indicator, and the abs light come on when I turn the lights on.
The van starts and the gauges work fine so the cluster is not shot. Any idea what could cause this behavior?
Discussion Starter #2
Flex cable ripped. Not sure if that is supposed to be glued down or what but the flex cable came right on with the plug and ripped. Any suggestions on repair? Is this even repairable?
Going to be hard and expensive to replace the cluster, is from E350 van... fml
I'm sure that it is reparable if you are capable with dealing with electronics.
There are a few shops that deal with instrument cluster repairs. I have dealt with RT Grim Electronics but they are not cheap. But you might want to give them a call and see if they can help you.
You may be able to use a repair kit for window defoggers.
Sent from my SM-N960U using Tapatalk
