So I have checked all my fuses and they are all good just no headlights at all has anyone had this problem no sure if it's a switch or if there is a relay I should look for
If you have nothing to any of the headlights (high or low beam), you might want to check the multifunction (dimmer) switch. Everything goes thru there. Could also be the headlight switch is bad.
