On my 93 f350 7.3 idi, I fully rebuilt the motor and after I bolted the motor back in and got the wiring harness hooked up I have no power to the interior when the key is turned. The power distribution box and interior fuse box has power but no light or chimes on the dashboard. I cant figure out what is wrong.
My first suspect wouldbe a bad ground somewhere.
Did the ground strap between engine/frame/body get reinstalled?
1993 F350 Crew Cab Dually
7.3L IDIT with a Banks Sidewinder
ZF 5-spd manual transmission
Problem is most likely at the relay behind the battery on the passenger fender. Take a picture of it.
Sent from my SM-G988U using Tapatalk
I agree with 79jasper. Did you hook all of the wires opposite of the battery cable? Just the one running down to the starter solenoid should be hooked to the downstream side of that relay. everything else should be attached with the battery cable.
