I have looked all online asked some people no solution. Put in new oil cooler went to go to work and no dash lights headlight or taillights I can pull the handle and brights will flash but nothing else and they won't stay on. All fuses under dash r good don't know where fuse box is under hood can't find it not in same place as my buddies. Is there a relay that could be bad that caused this
04 f250 6.0
Welcome to TheDieselStop :smile2:
If the fuses are good, it almost has to be the headlight switch. It gets power from the same fuse as the flash-to-pass function which bypasses the switch to directly power the high beams.
You won't find a fuse box under the hood on your '04. That went away for the '02 model year, when Ford consolidated all the fuses and relays under the dash.
