Hi first time writer i have a 2000 EX and had to repo from some people that dump dirt in the oil removed the valve cover on the pass sire and vaccumed out all the rocks drained the oil and poured diesel down to flush let dry also found ipr to be stuck pulled apart and cleaned got oil pressure but no start then pulled hpop and found rocks in the screen in the resivor cleaned out everything got new pump and ipr installed and started right up drove 60 miles parked it next morning started right up drove a mile and died crancking no oil pressure wts light is coming on tach is moving any suggestions thanks josh
