Hey everyone,
My parents are using the truck today to move my brother to school in Klamath Falls, they got most of the way there, went to pass someone on a hill, and at WOT the truck would not pass 60mph and "Started Running Rough". They got to the top of the grade(6 or 7%, not huge) and the truck smoothed out and went back to doing 75 no problem.
I did send them with an elm327, got them to pull codes and it had a p1209 stored. Had them pull hydra, and they are currently back on the road, with gauges up on the phone for HPOP and Duty cycle. They will be monitoring them if it exhibits the same symptoms, right now at around 75mph(foot control not on cruise) they have seen HPOP as low as 721 and as high as 1470psi, hovering around 950psi, and right at 25% IPR.
What am I looking at for a cause here? Had Dad check the ICP, no oil on the connector, have recently done the fuel bowl pressure regulator that is on the return line, and the hutch mod. Also the mechanic did a Napa HPOP about 3 months ago.
