Runs Great not rough starts great, just way down on power. Towed home the other night was running fine couple days later went to drive to work it started right up no excesive smoke all normal but as I rolled up to speed was like the chip was dead. changed the fuel filter and plugged in the old Dyno sources hard chip and no difference wont make over 8 psi boost or 700 degrees. put the TS chip back in on 140HP and rolls lots of smoke and takes off as good or better than it always did, 32psi boost and 1500 degrees like normal but switch it back to a setting I could tow with and its lots of throttle just to do 70 mph.
