I had a major fuel leak in my 97 F350 on my way to work the other day I wound up having to take the following day off work. I spent about 7 hours laying on top of my engine removing the turbo and waste gate so I could get to the fuel fittings going into the back of the engine off from the fuel yolk.
After all was said and done I got the truck started and went inside to change. After I got back in the truck I noticed my oil gauge was not working but the truck was running fine and I knew there was plenty of oil in the truck. I drove it home and it ran like a top. I shut it off and now it won't start (going on two days now). I was curious if the oil gauge not working would cause the no start.
If anyone has any suggestions or helpful ideas it would be greatly appreciated.
Generally no since the gauge is really just a glorified idiot light. It doesn't display pressure other than if it is above a setpoint like 6 psi, where it just reads mid scale (the sender is really only a switch, so it's state is only OFF or ON). If you do not have sufficient oil pressure for the gauge to register, then yes it would be related. Is the Wait-to-Start light coming on? Is the Check Engine Light illuminated? Check the main oil level. Cheers!
Thank you for the reply I got the truck running again (combo weak batteries and bad glow plug solenoid). Also the oil gauge works again didn't do anything to it.
