I recently in January had the ficm power supply changed while having a cold start issue in January. Problem fixed. Recently I have been having a resurgence of the problem on cold mornings but it evolved into warm start problem but fine once warmed up. Then it go so bad it wont start. So I changed the powersuppy board myself. Still won't start. Giving off codes for crankshaft and camshaft and MAP sensors. I am banking on a cam and crank sensor codes flaring on because of no start cranking. Can a faulty MAP cause a no start condition?
