Alrighty, For the past while I have had the abs light with no speedometer. I have checked wiring and replaced both sensors on the transmission and done the same for the rear diff.
When I stopped by the shop, and threw the code reader on, it cannot communicate with the ABS, at all. like it doesn't exist.
I am curious if there is anyone else who has experienced similar. I suppose Im hoping that its one of those quick and easy things.
thanks for any help folks,
· Administrator
Have you checked the fuses for the ABS module? A blown fuse may cause the issues you're seeing.
I have. Off the top of my head I think it was #26 or something like that. I ended up checking some other potential culprits with no luck.
I am not a huge electrical guy but I did have one thing that crossed my mind that I am not sure if it would have influenced my problems. I had a bit of a short with my trailer wiring fairly close to when my problems started. My Power supply at my 7 pin plug rubbed through and corroded bad. Would there be any chance that it somehow back fed to my ABS module or something along those lines?
