November 2018 ROTM Vote
  • mayer57619
    Votes: 0 0.0%
  • WhiteBettyOBS
    Votes: 0 0.0%
  • bodymann
    Votes: 1 50.0%
  • Calico5
    Votes: 1 50.0%
Status
Not open for further replies.
Administrator
Here are your contestants for this months Rig of the month!
mayer57619
My 2009 F350
WhiteBettyOBS
White Betty doin OBS stuff
bodymann
My 95 dually
Calico5
Ready for the Season (desert, that is...)!
2000 F350 Superduty, with all these current Mod's:
(Pics taken 11/11/18)
AFE Intake box with custom inlet tubing, Garrett GTP38R turbo with non-EBPV pedestal, Bellowed S/S Up-pipes,
DieselSite turbine jacket. HPS Hi-temp aramid/silicone CAC Boots; Banks Big IC, "BanksBrake" engine brake.
Custom external oil cooler & remoted filter system; Stealth 4-line, twin Bosch 008X HPOP's, Melling LPOP,
Swamp's 160cc/30% Injectors and "HVHF" IDM, DP-Tuner F5 chip and tuning, Fluidamper harmonic damper.
Custom-built, full regulated-return fuel system with Bosch pump and pre- & post-pump spin-on filtration.
Mishimoto all-aluminum welded radiator and aluminum de-gas tank, with custom-fabricated bracketry,
"real" Navistar T444 water pump w/coolant filtration, DieselSite silicone hoses. Strictly Diesel aluminum dip-stick adapter.
4" turbo-back, custom under-bed S/S exhaust into twin "Aussie" stacks.
SouthBend Double-disc clutch and clutch hydraulics, ZF 6-spd manual trans with CoreShifter's "Hurst" short-throw stick,
GearVendors Over/under drive aux. trans. PowerMaster 9051 "Ultra starter".
ProComp 4" lift, Rancho RS7000 shocks, FabTech rear traction bars, AFE aluminum rear diff' cover, ARB nodular-iron front diff' cover,
ProComp 17" aluminum rims with 36" Falken "Wildpeak" M/T tires, BuckStop front and rear bumpers. '04 Ford "Aero" clear headlights.
Status
