OASIS Special Service Messages - 1994-1997 Power Stroke FAQ
285 Views 1 Reply 0 Participants Last post by  DieselStop Content
Courtesy of: Ford Motor Company Publication FCS-12178-97
SSM NUMBER: 4102
EBP solenoid serviced separately from turbo
If you encounter a 1994-95 7.3L DIT engine with an rpm/speed limitation associated with black exhaust smoke, and possibly a Code 478, check the EBP Solenoid (F5TZ-6C673-A). Replace the solenoid rather than the entire turbo assembly. It is serviced separately.
SSM NUMBER: 4249
Oil filter torque
The torque specification for the 7.3L DIT oil filter has been revised to 27 N-m (20 lb-ft).
SSM NUMBER: 4293
Check clamps and connections at turbo
If you have a report of an exhaust smell in the cab of the 7.3L DIT, check the clamp on the turbo down pipe to turbocharger. Also check inlet pipes to turbocharger and manifold for loose connections or exhaust leaks. Tighten as necessary. Be sure not to position the clamp to create a grounding issue.
SSM NUMBER: 4301
Normal condition - blue smoke on restart after idling
For 7.3L DIT engines, blue smoke on start up following extended idling with the blue smoke disappearing after a short drive at normal operating temperatures is considered normal and no service action is to be performed. White smoke on cold start up on 7.3L DIT engines is a normal characteristic. This condition is common to diesel engines and does not call for service action.
SSM NUMBER: 4418
Film of oil/dust normal - if not dripping, do not service
Seepage of oil between the halves of the turbo and the small amount of oil in the intake deposited by the positive crankcase ventilation system are frequently misdiagnosed as oil leaks on the 7.3L DIT engine. The seal on the turbo allows a very small amount of oil to weep through and this may attract a film of dust. If the seal is not dripping, DO NOT ATTEMPT TO SERVICE IT.
SSM NUMBER: 4774
Install quality fuel and operate at speed to clean up catalytic converter
Investigation of a plugged catalytic converter on a 7.3L DIT engine indicated that a very low grade diesel fuel, probably not intended for highway use, was being used by the fleet. The concern was resolved by draining the tank, purchasing known quality fuel from a local service station and operating the vehicle at highway speeds for about 15-20 minutes while the plugged condition cleared. The low power complaint cleared as the converter self-cleaned.
SSM NUMBER: 4808
Check for missing oil filter relief valve
A missing oil filter relief valve in the rear oil cooler header is a possible cause of a start/stall with no oil noted in the reservoir, rough idle, or irregular oil pressure gauge readings. The three pieces of the valve (spring, fiber washer, steel washer) can fall out of the rear oil cooler header while removing the oil filter due to the lack of enough retaining stake. If all pieces fall out an are recovered, the proper order to reinstall these pieces is: spring, fiber washer, and steel washer. Stake them back in place. The valve is not serviced separately. If any piece is missing, the rear oil cooler header must be replaced.
SSM NUMBER: 5005
Check for short in Circuit #16 - replace fuel heater
Some vehicles may come in with Fuse #22 (30 amp) being open. Other symptoms may include stalling, no start, or a "wait to start" lamp that will not come on. If so, check for short to ground in Circuit #16 from Connector C138 (42-pin) to C188 at the fuel line heater assembly with both connectors disconnected. If the circuit checks OK, replace the fuel heater element.
SSM NUMBER: 5011
Remove trapped air after repair
The cause of Codes 1211 or 1212 can be internal or external leaks, a faulty IPR, a faulty ICP, injectors, high pressure oil system concerns, low or improper oil, trapped air, loss of oil pump pressure, or PCM or wiring issues. Make sure trapped air is purged from the high pressure system by running the vehicles hard for 20 minutes after a repair to avoid false codes. Use 1996 PC/ED symptom flowcharts 3, 10, or 17 and record results of checks on the 11x17 Diagnostic Guide. Only run pinpoint tests when directed by the symptom flowcharts.
SSM NUMBER: 10389
Aftermarket products may cause severe engine damage
There are various manufacturers offering devices to increase turbocharger boost or otherwise increase the power/torque of the 7.3L DIT engine. Many owner's past experience with products of this type has been very poor. Severe powertrain damage may result from use of these aftermarket products, which will not be covered by the Ford warranty.
SSM NUMBER: 10614
Acceptable smoke levels and factors explained
White smoke from the exhaust on start up in cool to cold temperatures on the 7.3L DIT and other diesel engines is normal. Acceptable levels could be described as a puff of smoke followed by very light white smoke for the first kilometer (mile) or so. Some factors which will affect the smoke are fuel quality, fuel range (1D, 2D, and winterized 2D), temperature, oil quality, API rating, and oil viscosity. All engines are now shipped year-around with 10W30 oil from the factory.
See less See more
1 - 1 of 2 Posts
1 - 1 of 2 Posts
