I have a 99psd that is not giving power to the right turn signal wire at the trailer plug. All other lights and the left brake and turn signal are fine. I checked all this at the truck side 4 pin plug and I know that I am not getting the 12v there to the right side terminal.
Where should I look now to find the problem?
Any help would be greatly appreciated.
Discussion Starter · #2 ·
I guess no one has ever had this kind of problem before. I was hoping someone would know if maybe there was more than one flashed relay somewhere or something.
· Administrator
Do both trailer stop lights work when you mash the brake pedal?
If not, check fuses 1 and 3 (both 7.5A) under the hood. They feed the stop/turn signal circuits left and right, respectively to the trailer. The fuses branch off the circuit for the truck stop/turn signal circuits.
Glad I found this thread, mine is doing the exact same thing. All lights work except for the right turn signal.
Steve
My right side signal wasn't working my camper. I finally got under the truck with my test light. I wasn't getting a signal at the receptacle at the bumper. I unplugged the receptacle from the harness. I had power from the harness & when I plugged everything up I had power to the receptacle. I guess th plug must have corroded. Royce:thumbsup:
