OEM water separator filter / filter head removed from an 88 E350 7.3. The filter element is brand new with less than 30 miles on it. I replaced the OEM unit with a spin on with drain and relocated it so all the injectors and glow plugs are accesible just by removing the air cleaner housing.
Send me a pm if you are interested. Eveything is in good condition as far as I know, schrader valve, bleed valve, drain valve, WIF sensor, heater, no leaks.
