Well about a month ago my steering wheel started wiggling back and forth a bit on certain roads....annoying but who cares. Then my front right tire started wearing weird. (BFG mud terrains) This made me nervous. Had ford check it out to see if there were any major issues. Said everything was fine. What a joke.... They just re-aligned it, changed the toe a bit, rotated the tires and checked to see if everything was tight looked ok etc... Soooo I left thinking problem solved right?? Not really....The steering wheel now wiggled worse, the truck has a horrible ride, and is extremely sensitive to any uneven road surfaces, esp at the 45-50 range and in left hand sweeping curves. Well it has been a week and the problem worsens every mile I drive. Last night on my way home from work the steering wheel really started to wiggle bad, then the whole front end started wiggling doing barrel rolls etc... Scared hell outa me!! I could barely control it!! Sooo I got on the good ole internet and did some research. Sounds like death wobble to me...maybe not but it sounds very similar. I need suggestions to get this fixed asap. Any suggestions... comments places I can contact (im in ohio)... what to tell the retards at ford... fixes... etc... /ubbthreads/images/graemlins/confused.gif My truck is one of the early 05's 4wd crew cab has a rancho 4" lift, and bfg mud terrain 35's. Any help is much appreciated!!!! I have parked it permanently until I find a fix. I hate driving my junker 93 dakota!! /ubbthreads/images/graemlins/mad.gif
Thanks!!
Andy /ubbthreads/images/graemlins/confused.gif /ubbthreads/images/graemlins/shrug.gif
Thanks!!
