So, who is running an oil bypass filtration system?
Did you by a setup or build your own?
If you built your own, what filters are you using and what is the micron filtration specs? You mount base specs would be great as well.
I am trying to put my own together and trying to determine an assortment of filters to use that have the same thread specs to narrow down what filter base mount to buy.
I am having a hard time find filter specs to determine the part numbers for filters that will filter at minimum of 5 microns, I would love to get down to 2 microns. And, I understand the micron ratings and the difference between the "nominal" and the "absolute" micron ratings...
Also, are you using hydraulic hoses or using rubber transmission line with barb connections.
One last thing, I would like to dump the filtered oil back into the oil pan. Where would I find the fittings that I could thread into a hole punched in to the pan? I have seen this done and it looks very clean and secure.
