Administrator
Yes, an oil cooler leak can put oil in the coolant and coolant in the oil.
And it doesn't necessarily mean the cooling tubes have failed. It could just be a bad internal o-ring.
The oil cooler is positioned on the DS right under the DS exhaust manifold, a very hot location for a "cooler". The O-rings get cooked, turn brittle and leak. When I changed mine the o-rings fell apart when I pulled them out.
Obviously someone that towed often, or had a heavy right foot habit, would generate more exhaust temp more often.
I don't so my first change was at over 200K. Likely if there were a heat shield between exhaust manifold and cooler they would last an average users unit lifetime.
The coolant system cleanup after the repair took longer that the physical cooler o-ring replacement.
Good practice to change oil after then run it 500 miles, get an oil sample to confirm no water in oil.
