21 - 31 of 31 Posts
Discussion Starter #21
Hope he doesn't strip my pan. lol
Thats my concern!
Except I am worried I will strip my oil pan.
I re-used a copper washer and had a fine layer of oil on the bottom of my oil pan for the first time. Thats what got me thinking about this.
As for the Fumoto mentioned earlier, my fear is I will snap it off. Been doing alot of ranch/forest service road this year with rocks and ruts.
Just rode through big fresh snow this weekend at Rabbit Ears Pass and then the Snowy Range this morning.
I've done about 35 oil changes on my truck and today was the first time I ever replaced the copper washer. It did look like it was due... or overdue.
All your trucks are 4x4. I wouldn't worry about snapping them off as I mentioned earlier.
If you're concerned about leaking copper washers, they can be reconditioned by annealing them. Just heat them cherry red with a propane torch and let them cool. They're now soft copper again. Of course, once you have a seep with one, it's too late to replace it.
Thats my concern!
As for stripping it you will strip the bolt before the pan nut since the bolt is a softer metal than the pan nut.
On the Fumoto valve, you should go for a ride with me when I am out and playing around in the wilds. That is where I will say that if you do happen to snap it off you have bigger problems than just the valve. Just crawl under your truck and take a look at the location of the drain in relation to everything else that is going to get damaged first.
Discussion Starter #25
That might say more about you than the washer...Lol
Seriously though, I would lose sleep doing something like that.
Discussion Starter #26
Thats good to know about the pan threading.
I believe all of you about the Fumoto being safe from damage...but if you knew how my last two years have played out, then you would believe me when I say mine would be the one in a million that gets hit by a rock.
Thanks for all the participation in the thread.
I have been known as a person that can break anything if it is possible to break it. And I have proven it to those that think that by doing just that.
Perhaps that is why I have a small machine shop in my garage. To fix what I have destroyed.
What Kevin said- all of our fabricated parts (Olin Brass) are annealed after about two processes of extrusion, Copper and Brass Products. However, after a couple uses of the oil pan washers I believe they would get a groove or wear pattern that might lead to problems.
Yeah, the grooves prevent you from doing the anneal process more than once or maybe twice.
Discussion Starter #30
Thats what I enjoy so much about TDS...in-depth reviews of even something that first appears a simple copper washer.
:winking:
:winking:
Agreed! And thanks to all the comments, I went ahead and ordered a fumoto. Great timing too...I was planning on changing the oil this weekend and it's in the mail today!
21 - 31 of 31 Posts
