So. I have oil coming down my exhaust pipe right after starting the truck up. White smoke. When the truck warms up it is fine. No issues. I've been doing some reading and am thinking it is the turbo. No milky on the dipstick. Came here to get some more opinions. What do you think fellas?
Could also be the start of head gaskets... You say it is oil, is this because it is black? If so then have the pressures checked because when I first bought my diesel used about a week went by and I had the same issue. Thought it was oil and it was actually radiator fluid that had turned black from the exhaust! Had it bulletproofed with a head gasket job and she runs like a raped ape!!
A head gasket job is about $3,000 give or take depending on location, the MODs added approximately another $3,100 but I had EGR Deleted, ARP Studs, Custom Exhaust and a Livewire+ tuner installed
Check your coolant level. If low, pull the EGR valve and look for moisture after the truck has cooled. Also look at the right side exhaust manifold where the up pipe connects and inspect for evidence of coolant leaking. These things will point to a failing EGR cooler. After shut down clooant leaks into the cooler and runs back down the right up pipe where the cooler is connected to. Head gaskets will not cause your symptoms. The fluid in your exhaust pipe is most likely coolant mixed with the carbon in the exhaust giving it the appearance of oil - a common incorrect identification of the fluid. Oil would only make it that far if the turbocharger seal or bearing completely failed and was dumping oil into the downpipe and you would have extreme smoke that will not clear up. The EGR cooler is your most likely bet. Good Luck! :)
