Recently my trucks small oil leak has gotten worse. Weather has turned a little cold -2 Celsius. I've been plugging in but on start up the truck is really running rough. Oil is leaking from above the starter and is noticeable and worse the last few weeks. Working from first light to dark so have not been able to clean the area yet or take pics. At the min i have a few tablespoons or a bit more of oil after each stop.
Looking for some ideas of causes for the leak and or rough idle (goes away when warm and runs great)
I've researched possibles as being
Glow plug harness (1)
FICM (2)
ICP Sensor (3)
No check engine light. I have a cheap code reader which i will plug in but not seeing any engine light,
Well i will correct my earlier info. Plugged in last night at about -4 cel and a good start. Not sure why the block heater was not working the other days? Not plugged in my truck is still rough at start. (last night after work) I cycled the plugs twice and my batteries are 2 yrs old 950 CCA and over 14 vlt. I put my cheap coed reader on this morning and no codes.
Lot's of oil on the cardboard from last night
FICM (2)
ICP Sensor (3)
