HPOP lines or plugs,I found a small oil leak in the valley while changing my gpr. The oil is in the little recessed spot in the block under where the innercooler pipes join. Any ideas where to start looking?
Might be the boots oozing a little oil. A seep there can turn wet if it seeps long enough. Make sure the boot clamps are good and tight, and if that doesn't stop it, you may have to remove the boots and clean everything up, then reinstall or replace the boots.I found a small oil leak in the valley while changing my gpr. The oil is in the little recessed spot in the block under where the innercooler pipes join. Any ideas where to start looking?
Since MondayHow long have you owned it? If the oil was "Wet" it wouldn't be there really long. Clean it out good, (rag and brake parts cleaner) and keep your eyes on it....:thumbsup:
