Hey guys,
I have a oil elak. I can't tell where it is coming from. I replaced my Valve cover gaskets when I changed my GP's and wiring harness. I am 99.9% sure it's not leaking from the VC's I felt all the way around and looked real hard with a flash light. I think it's leaking in the valley some where. I think it's coming from... There's a piece that looks like where the waste gate would be at on the new ones( but since we don't one) and it's a black looking tube that branches off to the passengers to the left before it goes through the turbo,it then leads down to head to rectanglular mounted bracket. Sorry for the bad explanation, new to all this stuff. Please help?
There are some plugs along the inside of the heads(oil galley plugs I think they are called). They have o-rings on them that tend to spring a leak once in a while. You might check them out.
Maybe EBPV actuator or turbo pedistal leaking. /ubbthreads/images/graemlins/shrug.gif
thanks guys, hopefully I'll figure this thing out, thanks for the info.
