1 - 10 of 10 Posts
I am wanting to install the "actual" oil pressure gauge I had in my 97 in my '05 6.0L. The '97 had a handy orifice at the front of the block. Is there a similar location on the 6.0L?
I hear a lot of guys putting them in the top of the oil filter cap. I also would like to know too. Kind of would be a pain changing oil every time to unhook the wires, or unthread it from the cap so you could use the socket.
Has anyone hooked it up there? I think that I have tried to look for it on the truck, but couldnt find it or stuff was in the way. /ubbthreads/images/graemlins/shrug.gif
Climb up there and look down just behind and slightly left of the filter buried down between all the $hit. I had my bypass filter pressure line plumbed out of the pressure switch port for 2 years until I removed it last month. Giterdone!
Snoboy, are you indicating I should remove the oil pressure switch and replace it with my autometer sending unit?
My bad! I thought you were doing a mechanical gauge. You'll need a street T and a sending unit adaptor so you can tap both sending units into the same spot /ubbthreads/images/graemlins/bleh.gif. Or you could buy the Oilgaurd filter 6.0 filter cap and put the Autometer sender in it. Looks cool /ubbthreads/images/graemlins/smokin.gif and less PITA then the aforementioned method. Its your call bro. /ubbthreads/images/graemlins/shrug.gif
Discussion Starter · #9 ·
Thanks for the ideas. I'll have to play around with them both.
I have the FS-2500 bypass and could probably get a T for the cap. But since there are two un-used ports in the filter housing I'm going to try the un-used pressure port.
1 - 10 of 10 Posts
